Help with starwars:Controll settings
Posted: Sat May 20, 2000 12:30 pm
by QRS
I4m planning to upload some scores on Star wars but I can not see any options to play with the mouse or trackball.. To play with the joystick is really hard I can tell ;)
Anyone who can help me with that??
Regards
QRS
qrs@telia.com
by Q.T.Quazar
It defaults to mouse or trackball. Setting controls are under 'Analog
Controls' from your main menu inside MAME. There you can adjust control
settings and sensitivity. Buttons are changed from Keyboard or Joystick
to Mouse inside the 'Game Input (this game)' section of the main menu.
Anxious to see what you can do. I'm practicing this game at the moment
as well so that I can vie for first on the entire trilogy. We'll see.
QCN
qan@home.com
Posted: Sun May 21, 2000 12:30 pm
by QRS
Damn it QT! I can not get my controls working properly...
The mouse works now, but the playing with it I can not score high at
all... For the moment I score more with the joystick...
Those highscores om marp on Starwars are not good... but I asume that
they had the same control problems as I have ;)
Regards
QRS
ps is there any way to set up the controls on the mouse so you
go up when you push up? I mean the reverse pilot controls don4t fit me
with a mouse... but on the arcade it was diferent.. on the real pilot
joy in the arcades the control was excellent with the reverse
controls..
qrs@telia.com
by Q.T.Quazar
To adjust mouse sensitivity settings, change the sensitivity values
under 'Analog Control', not the Key/Joy Speed (that's when you are
using keyboard or joystick as an analog substitute. You'll likely have
to lower the settings a bit, because they are quite sensitive at
default.
To reverse the up/down, change the AD Stick Y Reverse from Off to On,
again under 'Analog Control', in your main menu.
I am anxious to learn, master. Let's see what you can do.
QCN
qan@home.com
