To adjust mouse sensitivity settings, change the sensitivity values
under 'Analog Control', not the Key/Joy Speed (that's when you are
using keyboard or joystick as an analog substitute. You'll likely have
to lower the settings a bit, because they are quite sensitive at
default.
To reverse the up/down, change the AD Stick Y Reverse from Off to On,
again under 'Analog Control', in your main menu.
I am anxious to learn, master. Let's see what you can do.
QCN
qan@home.com
