Posted: Sat Apr 26, 2014 5:40 pm
by tar
Re: 1943
Posted: Sun Apr 27, 2014 1:27 pm
by CrazyKongFan
I'm not a MARP confirmer, but I just finished playing back the 1943 one (not 1943j). I got really close to his score, although it was a bit short. It showed as 2783650 for the final score for me:
- 1943.png (14.32 KiB) Viewed 9232 times
- 19430000.png (3.99 KiB) Viewed 9232 times
but it's submitted in the wrong romset. On 1943, it says 1943 became 1943u in revision 138u1. Since he used wolfmame106, it should be under 1943u, not 1943. RichyS and ballas recordings should both be moved too, as they were both done with wolfmame106 as well.
Re: 1943
Posted: Sun Apr 27, 2014 2:33 pm
hmm, I'm getting the same as CCF.
2783650 for the 2787750.inp and 2561960 for the 2560961.inp
using wolf106.exe with crc=3344f202 full unthrottled -fs0 with -fs11
Re: 1943
Posted: Sun Apr 27, 2014 9:16 pm
He could be re-uploading INPs that have been previously DQed for autofire, don't suppose anyone checked for that?
Re: 1943
Posted: Sun Apr 27, 2014 11:25 pm
by simpsons99
mahlemiut wrote:He could be re-uploading INPs that have been previously DQed for autofire, don't suppose anyone checked for that?
I agree I bet Auto Fire was used
Re: 1943
Posted: Sun Apr 27, 2014 11:58 pm
by CrazyKongFan
wlfview shows the one I watched was recorded on April 24, 2014 at 18:24 (on his system) and it was uploaded here on April 25 at 00:11 (MARP time), so I doubt it.
Re: 1943
Posted: Mon Apr 28, 2014 12:27 am
Yep, it's autofire. It's gone now.
Re: 1943
Posted: Tue Apr 29, 2014 2:58 am
by simpsons99
He just ups his score by 1 point and resubmits his score
Re: 1943
Posted: Sat Oct 04, 2014 6:05 pm
by saulonpb2
wolfmame 106 is oldest than 14x versions, is more aproaching of the original arcade machine.
Re: 1943
Posted: Mon Oct 06, 2014 1:20 am
by simpsons99
saulonpb2 wrote:wolfmame 106 is oldest than 14x versions, is more aproaching of the original arcade machine.
does not change you used auto fire
Re: 1943
Posted: Mon Oct 06, 2014 2:18 am
by BBH
What?
Looking past the problem of uploading recordings to the wrong romset when they've since been shuffled around since the ancient version 0.106 (understandable since things change and one can't be expected to keep up with every rom change that's ever occured with games that causes romsets to be renamed), you still keep uploading recordings to the 1943 romsets that are using autofire. You say you're innocent and demand proof that you're using autofire? Anybody can see the proof if they playback the recording with -inpview enabled. There's consistent inputs the entire time on the 1 button that consist of one frame on, one frame off. There are no human beings that can press buttons at a rate that fast and so consistently the entire game. Especially seeing how there are other replays you have submitted to MARP where your firing rate is NOWHERE near that consistently fast. It's 100% autofire.
Re: 1943
Posted: Wed Oct 08, 2014 1:26 am
by Novice
if you want to try highscore of autofire, then you should try arcadia field. maybe much greater achievement than marp top.
require twice shot at every stage and at least 5 mobi-chan.
Loop yamato (stage 16) as possible.
current record is 4402550.
anysome, do in marp as the marpers do.
do not use autofire here. other men are a little wiser than you. and find out you used it.
