1943
http://replay.marpirc.net/inp/4/4/c/snp ... olf106.zip
http://replay.marpirc.net/inp/6/9/6/snp ... olf106.zip
i get 290,ooo
and 338,ooo
nvram is not an issue
m106 does not allow sound to be disabled
CrazyKongFan
Re: 1943
Post by CrazyKongFan »
I'm not a MARP confirmer, but I just finished playing back the 1943 one (not 1943j). I got really close to his score, although it was a bit short. It showed as 2783650 for the final score for me:
but it's submitted in the wrong romset. On 1943, it says 1943 became 1943u in revision 138u1. Since he used wolfmame106, it should be under 1943u, not 1943. RichyS and ballas recordings should both be moved too, as they were both done with wolfmame106 as well.
Re: 1943
hmm, I'm getting the same as CCF.
2783650 for the 2787750.inp and 2561960 for the 2560961.inp
using wolf106.exe with crc=3344f202 full unthrottled -fs0 with -fs11
Re: 1943
He could be re-uploading INPs that have been previously DQed for autofire, don't suppose anyone checked for that?
simpsons99
Re: 1943
Post by simpsons99 »
mahlemiut wrote:He could be re-uploading INPs that have been previously DQed for autofire, don't suppose anyone checked for that?
I agree I bet Auto Fire was used
Arcade Game Scores
CrazyKongFan
Re: 1943
wlfview shows the one I watched was recorded on April 24, 2014 at 18:24 (on his system) and it was uploaded here on April 25 at 00:11 (MARP time), so I doubt it.
Re: 1943
Yep, it's autofire. It's gone now. :)
simpsons99
Re: 1943
He just ups his score by 1 point and resubmits his score
Arcade Game Scores
saulonpb2
Re: 1943
Post by saulonpb2 »
wolfmame 106 is oldest than 14x versions, is more aproaching of the original arcade machine.
The Expert keyboard
simpsons99
Re: 1943
saulonpb2 wrote:wolfmame 106 is oldest than 14x versions, is more aproaching of the original arcade machine.
does not change you used auto fire
Arcade Game Scores
Re: 1943
What?
Looking past the problem of uploading recordings to the wrong romset when they've since been shuffled around since the ancient version 0.106 (understandable since things change and one can't be expected to keep up with every rom change that's ever occured with games that causes romsets to be renamed), you still keep uploading recordings to the 1943 romsets that are using autofire. You say you're innocent and demand proof that you're using autofire? Anybody can see the proof if they playback the recording with -inpview enabled. There's consistent inputs the entire time on the 1 button that consist of one frame on, one frame off. There are no human beings that can press buttons at a rate that fast and so consistently the entire game. Especially seeing how there are other replays you have submitted to MARP where your firing rate is NOWHERE near that consistently fast. It's 100% autofire.
Novice
The greatest info supplyer
Re: 1943
Post by Novice »
if you want to try highscore of autofire, then you should try arcadia field. maybe much greater achievement than marp top.
require twice shot at every stage and at least 5 mobi-chan.
Loop yamato (stage 16) as possible.
current record is 4402550.
anysome, do in marp as the marpers do.
do not use autofire here. other men are a little wiser than you. and find out you used it.
DEFence CONdition
WAR 1<< >>7 PEACE
