crzrally
Posted: Tue Mar 09, 2004 10:25 pm
by Weehawk
Posted: Wed Mar 10, 2004 12:23 am
by LN2
since you mention crzrally, does mine playback for you? If not I can see if adding 2 frames makes it sync ok etc.
BTW, I have already beaten that score I submitted a bit ago.
Posted: Wed Mar 10, 2004 1:34 am
same here, and 8600 for ricks recording.
Posted: Wed Mar 10, 2004 2:00 am
by LN2
I upped a new and better replay.
I'll test it in VPC and try adding 2 frames to see if that helps.
It might be the car locations are different in which case it won't be compatible but if it's only a time sync issue then I should be able to fix that by adding 2 frames at the start.
Posted: Thu Mar 11, 2004 2:42 am
5700 now, pre frame edit.
