crzrally
crzrally
since you mention crzrally, does mine playback for you? If not I can see if adding 2 frames makes it sync ok etc.
BTW, I have already beaten that score I submitted a bit ago. :P
same here, and 8600 for ricks recording.
I upped a new and better replay. :P
I'll test it in VPC and try adding 2 frames to see if that helps.
It might be the car locations are different in which case it won't be compatible but if it's only a time sync issue then I should be able to fix that by adding 2 frames at the start.
5700 now, pre frame edit.
