Buttermaker
Posts: 788 Joined: Sun May 19, 2002 9:06 am
Post
by Buttermaker » Thu Dec 05, 2002 5:20 pm
What operating system are you running?
Haze
Posts: 350 Joined: Sat Mar 23, 2002 5:04 pm
Post
by Haze » Thu Dec 05, 2002 5:25 pm
xp, nothing special about my mame.ini (default) except frameskip is 0'd
Buttermaker
Post
by Buttermaker » Thu Dec 05, 2002 5:54 pm
Haze wrote: xp, nothing special about my mame.ini (default) except frameskip is 0'd
Same here. Just created a default .ini and changed only the rompath. Still doesn't work. Tried it with frameskip 0 too.
Posts: 4191 Joined: Mon Feb 04, 2002 10:05 pm
Post
by mahlemiut » Thu Dec 05, 2002 8:37 pm
Doesn't playback here either with sound on (WinME). I'd try XMAME if they hadn't removed INP recording and playback.
Post
by mahlemiut » Fri Dec 06, 2002 3:48 am
Strange. It plays back now. No settings were changed other than -nowindow (and I switched back to a window using Alt+Enter). Not the first time that this has happened with this game.
Buttermaker
Post
by Buttermaker » Fri Dec 06, 2002 3:52 pm
mahlemiut wrote: Strange. It plays back now. No settings were changed other than -nowindow (and I switched back to a window using Alt+Enter). Not the first time that this has happened with this game.
Tried that with wrx2's 1944 and s1945j and it didn't help.
Posts: 4463 Joined: Tue Mar 05, 2002 3:15 pm
Post
by Chad » Sat Dec 07, 2002 1:59 am
i played it back once and it failed, but now it works...
Abbe
Posts: 203 Joined: Wed Mar 06, 2002 12:32 pm
Post
by Abbe » Wed Dec 11, 2002 4:30 am
-Abbe
Post
by Chad » Thu Dec 12, 2002 11:49 pm
tenchi's works fine on 98. 435600
Posts: 1972 Joined: Fri Sep 20, 2002 9:38 am
Post
by destructor » Tue Sep 07, 2004 4:42 pm
I (win98) and Apatia (winXP) can't playback WRX2 inp. Use almost each option.
Crashes at the same place always - second boss.
Post
by Chad » Tue Sep 07, 2004 6:23 pm
since me and haze can play this back (well i think i was only able to once, i'll try again) then this will remain as advertised. Technically i could zero it since wrx2 hasn't also confirmed that they can play it back which would add up to three total that can play it back...
Posts: 2562 Joined: Wed Jun 25, 2003 7:43 am
Post
by Weehawk » Wed Sep 08, 2004 8:57 pm
Just for informational purposes, the WRX2 inp plays to 44,500 no matter what options I try with sound. Desyncs worse without sound.
