Rim Rockin
Rim Rockin
http://marp.retrogames.com/inp/tbm_rimr ... mame62.zip
http://marp.retrogames.com/index.cgi?mo ... rt&tourn=0
buttermakers latest attempts don't appear to playback, the one above playsback to 5-8, with or with sound/nvram. Timmikins other mame56 offereing playsback fine.
Mame.cfg is for DOS. I'm using the Win32 CLI version. The only parameters in my .ini file that are changed from the defaults are rompath, hwstretch and ctrlr.Chad wrote:hmmmm, can you post mame.cfg.zip mame.ini.zip and other options you might be using?
I'm not using any other options. I'm starting the games with "record.bat romname".
thanksAbbe wrote:Plays back fine to me. Yet another case of OS differences. Mame62 CLI on XP with sound on does the trick.
Confirmed.
unfarting believeable, this is not a 98/xp thing since i coudln't get it to playback in either. But i think i found it. Ok all you believers that playing back inps has nothing to do with settings: [Kfx] try playing it back with the line:
ctrlr hotrodse
set in the mame.ini file using cli mame. It works for me with that (or "hotrod") set as the cntrlr and doesn't work with out it (or doesn't work with it #commented out or with ctrlr set to "joy"). I usually use -cntrl to record only otherwise this would have worked just fine with my hotrodse set as the default option. I'm assuming Abbe has a similar cntrlr setting (maybe not hotrod) but it's proly not blank in his ini.
ctrlr hotrodse
Sorry to disappoint you, Chad, but my ctrlr line is commented out. I compared Buttermaker's ini file to mine, but couldn't find any interesting similarities. I attach my file too for you to examine.
By the way, after further testing all the clones play back nicely with or without cfg files, nvram files, sound, frameskip or throttle. It's really hard to screw up playback here.
-Abbe
RE
Well, I have tried every single way to get them to playback.. but I have failed. I talked with Buttermaker on irc and it seems like we had the same os, mame default settings etc.
Still no luck.. is there any other factor out there maybe?
yep a "quarter" will get you one half of a quarter.
nope abbe, can't get it to playback with your mame.ini. I still CAN get it to playback with buttermakers ini or my ini with a hotrodse cntrlr, but if i comment that out it doesn't work. So Abbe, can i ask: do you hve a hotrod hooked up? and KFX does this work for you or no? qrs, have you tried both Abbes and Buttermakers ini files?
