Crazy Climber bootleg ccboot2
Playsback perfectly fine here to the advertised 265,550.
fricken A. playsback fine when i go to windows XP. no playback in 98.
uhh.. I don't use XP, it worked perfectly under WinME.
are you really sure that different OS'es affect playback, Chad? I'm on Windows 98 and I had no problem playing this recording back with m32-3710. Sound on.
yes, positutely. still can't get it to playback in 98, even with the SAME registry/sound settings for both oses for mame32. But send me your sound frequencies just to be sure. also, it's not just me. roncli seems to use XP and storm uses 98, on two occasions one could playback and not the other (and i could playback on the os that the one could and not on the os that the other couldn't.)
one example is tapper, i can't play storms tappers back in XP but in 98 they work fine. i could not find a clear cut example (other than this one) of a recording that playsback in XP only (when i say XP i include ME, NT and all the other garbage microsoft put out after 98 ) but this one might be one.
viewtopic.php?p=11847&highlight=#11847
