pc-ebike
Posted: Mon Jul 15, 2002 10:01 pm
http://marp.retrogames.com/inp/zlk_pc_e ... _win61.zip
First of all, very impressive recording.
Second of all, some clerical errors were made in tallying the score. Below is the .txt file he attached, except slightly altered. His advertised scores are starred, followed by the actual score I saw playback in parenthesis.
Because of the complexity of this formula, I'd like someone to double check that the two times that I pointed out were wrong are actually wrong, and that there is 50.50 seconds not accounted for in his original total time.The rules are: you start with 3900 units. The time is set to 4 units per second. You get 5000 points for each race you qualify on. You also subtract the 3rd place time from your time and multiply that by 100 for additional points. You then total your score. The first 9 3rd place times are as follows: 1:24, 1:32, 1:30, 1:18, 1:28, 1:14, 1:10, 1:10, and 1:08. From then on the 3rd place time is 1:08.
My times for the race are:
55.50, 58.32, 55.26, 1:04.16, 1:11.48, 1:03.16, 1:04.51, 1:01.21, 59.84, 1:00.99, 1:00.83, 1:03.16, 1:02.48, 1:01.66, 1:02.57, 1:00.25, 1:02.09, 1:01.04, 1:05.60, 59.60, 1:01.37, 1:00.84* (1:00.81), 1:02.91, 1:01.34, 1:03.15, 59.60, 1:00.84, 1:02.84* (1:02:76), 1:03.34, 59.44, 1:00.52, 1:00.16, 1:01.96, 59.96, 1:00.73, 1:02.14, 1:00.01, 1:01.20, 1:02.84, 59.80, 1:01.04, 1:01.39, 1:02.03, 1:01.88, 1:00.33, 1:00.44, 1:01.26
Then the 3900 time units ran out.
I finished 47 races = 235,000 pts.
The total 3rd place time is: 84+92+90+78+88+74+70+70+68*39 = 3298
My total time for races completed is: 2836.57* (2886.96)
This gives me an additional 46143* (41104) points, so my total score is: 281143* (276104)
