Night Striker
Night Striker
http://marp.retrogames.com/inp/emu_nigh ... _win60.zip
Won't playback past stage C, regardless of whether sound is on or not.
Frankie
Post by Frankie »
No luck either.
3.888.480 points on stage C with all sound settings, and 3.586.940 on stage C without sound.
I noticed that its his first recording so maybe he recorded it on Mame60 and not Mame32-60 and mixed up the versions when he filled out the submit form.
I can't check that now. If no one else does it before me, I'll check that tomorrow.
Bye.
Novice
The greatest info supplyer
Re: Night Striker
Post by Novice »
mahlemiut wrote:http://marp.retrogames.com/inp/emu_nigh ... _win60.zip
It works well if you use mame60.
lo and behold another game that works in win98se only. At least for me when i use mame60 in xp it doesn't playback, but when i boot in win98se mame60 works perfectly. dang if that stage E music doesn't kick.
Dammit, what is going on here? Different OSes should not cause this sort of problem. Then again, neither should different sound sampling rates. This is one game I've never actually had a problem with before, either.
It played back in XMAME. :?
sikraiken
Post by sikraiken »
Hey Skito, I was wonderin if sometime we could talk about dual-booting, I wanted to find out how to do it so I can do a win98se and WinXP dual boot.
it's a major pain, took me at least a month to figure out how to triple boot xp,98, and linux reliably and allow the other partitions systems to see each other ok.
The main thing to remember is to install 98 FIRST, then install XP and linux since both of them can boot ok on "later" parittions. 98 must boot on the first partition.
sikraiken
Post by sikraiken »
Well, Windows XP is installed and dual booted with Windows 98SE. It is so great. :)
