Hello, I seem to be having problems getting M36b8 to run, and I assume it is because the latest Windows software is no longer helpful with DOS programs... it is now called COMMAND PROMPT. I don't know what to type to get mame to work. Do I need a frontend perhaps?
Whenever I try just clicking on m36b8.exe in windows, it opens the Command Prompt window for a split second but the window immediately closes.
Any help with getting this to work would be appreciated... I am dying to see the 1 million plus .inps for makaimura games.
bull444@hotmail.com
Can M36b8 run on Windows Professional?
Q.T.Quazar
ummm...the DOS version requires you type a command line of
information, best done (if you aren't using a frontend) from the run
menu under START.
typical playback for a recording would go something like this
mame <romname> <options> <.inp name>
<options> is fully described in the main MAME help file, which comes
with any official version of MAME (not necessarily the stripped down
versions available at MARP)
so a typical playback line for, say, Tron, would look like this:
mame tron -playback tron
Hope this helps, but I would recommend you read the help files
included with an official MAME release, also available at the MAME
site http://www.mame.net
qan@home.com
menu under START.
qan@home.com
Q.T.Quazar
if you can't run it like this, you should be able to right-click
m36b8, edit the properties, and type in the command line there.
qan@home.com
qan@home.com
Barry Rodewald
If by Windows Professional, you're referring to Windows 2000, then
you may very well have problems. It's likely you won't be able to
get any sound or VESA video mode support. Anyway, you'll probably
need to open a command prompt box, and move your MAME folder (ie; 'cd
mame' assuming that's where you've extracted MAME to), and
type 'm36b8 makaimur -playback makaimur' without the quotes of
course. Don't forget to extract the recording to the 'inp' sub-
folder from where MAME is located.
Probably the better option would be to get MAME32 0.36b8, which
should work without problems under Win2K.
bsr@hnpl.net
bsr@hnpl.net
Mr_Bunny
Thanks very much for the help! I tried the Command Prompt work-around
and it got me a bit farther... up to the VESA error.
A quick download of MAME32 of the correct version solved my problems.
Finally got to see a score greater than 1 million points on Ghosts n'
Goblins! That sure is a tough game! But not as tough as that other
Capcom masterpiece, Speed Rumbler. Whoever has the high score on
that game must be proud!
bull444@hotmail.com
bull444@hotmail.com
