*** To All Marpers: playback warning for m37b12 and Qsound
There are adverse playback issues if you use the fixed version or non fixed version of the official mame binary for the new qsound games. Please state the version you recorded with when you upload. So far all the games i've tried to playback only playback on the fixed or nonFixed mame version of which they were recorded with.
We may decided to only accept one of these versions, probably the fixed one. But untill then please mention which version you have recored with "Fixed" or "Not Fixed/origonal" 37b12.
You should know which version you downloaded because the fixed mame binary zip file will have a "_fix.zip" at the end of the filename, if it didn't please state you've uploaded a non fixed mame recording.
Thanks!
churritz@cts.com
Gameboy9
Post by Gameboy9 »
When I discovered what happened, I immediatly added a fixed line to
the submission list (m37b12f) - sorry to the person I DQed on the
ssf2 recording. GB9
goldengameboy@yahoo.com
ufox
Post by ufox »
What's the difference between those fixed and unfixed versions? Wich
one should we use for recordings? I think we should use the fixed
cause the unfixed is no longer available at mame site...
pedromag@e247.com
Both of them should be ok to use now that we have to entries in the
list, but please make sure you know which one you are recording
with. Fixed is probably better but "fixed Qsound games" could
mean "broken other games".
Here's a rule of thumb: any version is fine to use as long as you
tell us what settings/version you've used and can reliably -playback
your own recordings with it.
churritz@cts.com
I should add that any tournament edition of mame is prefered above
all others, i.e. m35tg3 and future versions. Using a tournament
edition of mame tells us you're not affraid of having your recordings
scrutinized to the utmost extent and thus probably a more honest game
recorder/player. Unfortunatley there's not a tournament edition that
plays the newer games passed mame35final, but hopefully there will be
soon.
churritz@cts.com
Barry Rodewald
Post by Barry Rodewald »
These are the changes to the fixed MAME beta 12 binary as far as I
know:
- Fixed the loading of samples in CPS-2 QSound games. This alone
would have no affect on playbackability (that's a word?)
- Enabled the ASM 68K CPU core. This is very likely to affect all
68K-based. This will probably affect all 68K based games (except
68020 games (Taito-F3, Psikyo), that is separate now, and still C-
based)
- Fixed the accidental breaking of Neo Geo games. They should all
work now.
So any 68000 or 68010 based games recorded in the first beta 12 is
highly unlikely to work in the fixed beta.
Hope this clears it up somewhat.
bsr@hnpl.net
