another os question: win2k/dos involved
david oliver
Post by david oliver »
i was thinking about this lately: i heard windows 2000 was far more stable than any other windows and is based on the WinNT kernel. the next consumer version of ms windows, whistler, is gonna be based on the winnt kernel which means very poor if ANY dos support. anyway back to win2k, what i was thinking is that would it be possible to make a win95/98 boot disk (that will boot to a command prompt) and use it on a win2k system? this way if i want real dos mode i can put a disk in to boot win95/98 in command mode complete with an autoexec.bat and config.sys with dos mode drivers for a sound blaster pci 128 (if any exist - i plan to use that card in my new computer) is it possible?
BTW i intend to run more than just mame in dos mode - there is a kick ass freeware dos game called "chickens 2"... TIA
davedude1414@yahoo.com
seymour
Post by seymour »
If you install Windows 2000 with 9x already installed, it should
automatically set up a boot menu so you can choose between the two.
How you go about setting up your Program Files and stuff is a
different matter (I haven't bothered) :)
Making a bootdisk for command mode only would work too, as long as you
don't use NTFS (which I wouldn't really recommend anyway, use FAT32).
MAME32 is pretty good though.
seymour@iname.com
Pat
Post by Pat »
Don't believe anything MS tells you!! They still continue to pump out
a lot of crap products and can't write bug-free software to save their
lives. What you say is possible, but to run MAME under pure DOS you
will also need a memory manager called CSDPMI. You can have this
loaded automatically at boot time. You'll get awesome performance!
laffaye@mail.com
david oliver
umm...pat...if you search my recordings you will find all of them are
done with dos mame so i'm well aware of CWSDPMI. i tried mame32 once
and i found it quite a bit slower than dos mame. for some reason it
just doesn't have the same "feel" as if running in pure dos than
mame32.
and as for what seymour said i thought about it - it will not work
with a win95 bootdisk because it wont support hard drives >2gb. (as
far as i know - does OSR2 fix this?)
Pat
Post by Pat »
Just because you submit DOS INPs doesn't mean you used the memory
manager!! A lot of players run DOS MAME from either a DOS Full Screen
or Window which does not require CWSDPMI.
BTW, a Win98 boot disk will overcome the 2 GB limitation...
laffaye@mail.com
