Why won't keys change?
Posted: Thu Nov 30, 2000 12:30 pm
by James Darpinian
I'm having trouble playing a Neo-Geo game, Samurai Showdown 2. It works just fine, but not all the buttons are available. When I go into the menu, it says they're assigned to "None". Then, when I try to change them, nothing happens! I can change all the keys that are already assigned, but I can't assign keys to buttons that aren't assigned a key yet. I've had this problem with other games too. Does anyone know why this is and how I can fix it?
J2274645@cheese.com
Posted: Sat Dec 02, 2000 12:30 pm
by Richy Cream
Right click on the game and check the properties and make sure
joystick is checked. If that doesnt work, then what kind of input is
it? If you are using your USB port than you need to uncheck use
direct input.
chris66336@juno.com
by Barry Rodewald
I suspect you are trying to define buttons 5 to 8... My
understanding is that those buttons can only be used with -cheat as
they mimic multiple of a 'regular' button (ie: 1 to 4). You just
need to define buttons 1 to 4 (and of course the direction keys).
Neo Geo machines only have four buttons.
bsr@hn.pl.net
