I have a (stupid) question about Dodonpachi.
The question probably proves that I don't know that much about MAME, but rather play the games.
When I run Dodonpachi the screen is upside down and I can't even start
a game. Is there an option to rotate the screen and make it an 1 credit per game game? This last problem is probably the reason why I can't playback any .inp files.
Eagerly awaiting an answer,
Arjen
arjen@ukonline.co.uk
question about dodonpachi
Barry Rodewald
After the opening warning screen (you know, "prosecutedt to the full
extent of the jam") you can push and hold F2. Hold it until the
config screen appears. Select configuration, and push the key you
have defined for button 2 (default is Left ALT). This resets all
settings to factory settings. This shouldn't need to be done for
BBH's recordings, this is done as a part of his recording.
bsr@hn.pl.net
bsr@hn.pl.net
