Tourney 3 - How to record in TG settings in MAME AND KEEP TH
Posted: Mon Jan 31, 2000 12:30 pm
Load a game normally, w/o using the recording features. Change the DIP settings like you can in the DIP Settings window, (in Gauntlet 2, hit F2, reset the game with F3, then you follow the instructions to move on in the screens. Hit F2 again, and F3 again to return to the game screen. If it does service mode again, go to the DIP settings, and turn the service mode to OFF.)
Now all you have to do, for example, if you want to play amidaru using a changed TG settings set, you would just type this:
m35tg3 amidaru -record amidaru
This line will play the game using the settings that were saved in the CFG file.
If you use MARP's recording BAT file, it would essentially delete the CFG and HI score files, resetting the settings to default, and that would not be good.
Hopefully this will help all of you out - good luck!
goldengameboy@yahoo.com
