T. Alex Strikes Again - Solomon's Key This Time
Tim Morrow
Post by Tim Morrow »
I don't know how he does it, first with the Pitfall2 time and bat cheat and now with Solomon's Key.
Here I am innocently watching his recording. Very well played but everything above board. Then in level 30 (where the jumping enemies occur) he ducks down at the bottom of the screen and actually manages to build a block on top of himself - this was surprising enough. The next part was even more astonishing - he falls through the bottom of the screen and disappears!!! Then the level ends and he goes to the next level. How the hell does this work?
He tried the same trick later on (can't remember which level) but got stuck half on the bottom, half on the top of the screen and died when his time ran out.
I'd like to know where he pulls these tricks from. Too bad he won't respond to any of my email.
tjmorrow@bigpond.com
These might be just a game inconsitancies in the real arcade as well,
but one thing i noticed is that Alex started with one more life than
all the other recordings did. I'm sure this was unintentional, but
if the defaults lives for the game have changed in later mame
versions, the respectfull thing to do is to change settings to what
ever they were that people have recordded before .
at anyrate, he plays very very well.
churritz@cts.com
yep, in his 7M recording he started out with 2 more players that you
normally get (and than the other recordings received to begin the
game.) you should proly tell him this too in your mailings :)
churritz@cts.com
Tim Morrow
Guys,
T. Alex has replied to my email on the matter of Solomon's Key.
In his Solomon's Key recording If you watch carefully you will notice
that he is using the following modifications to the default dip switch
settings -
1. Lives Set to 5 (rather than the default 3)
2. No Bonus Lives (rather than bonus lives at 30K,100K,500K)
He changed these because when he was awarded a life from score his
game would crash through what he assumes is an emulation bug. He
therefore had to disable the bonus lives. He upped the lives to
compensate. He certainly wasn't trying to gain an unfair advantage.
Anyway just to set the record straight for all critics/skeptics he has
uploaded a recording with lives set to 3 and no bonuses which is
surely acceptable as it is undoubtedly harder than the default
settings. In this recording he gets a higher score than in his
previous best! Check it out!
As a side note, T. Alex has sent me a solomon recording where he gets
a high score of 60 Million (yep!) by exploiting the abovementioned
'ducking' trick in the last level of the game. I am urging him to
upload it to MARP under the 'weird' section.
