My thoughts on TG3
Posted: Fri Dec 17, 1999 12:30 pm
by Q.T.Quazar
I really don't like all this talk about a whole new leaderboard at MARP, and all the accusations being flung at players about cheating. The spirit of gamesmanship here is dying. I say that if a score looks suspicious, then let's follow the same rules as TG, now that we have a solid version of encoded MAME. A player challenged about his score has, let's say, 2 months to prove he can repeat 75% of his score using TGMAME, or the score is discarded after two months if he cannot. Players would be allowed to make one challenge against another MARPer per month, or so, I haven't really fleshed out the idea fully.
A couple other quick things that are really irking me. German Krol, PLEASE remove your autofire recordings, like herbiedk. Jeez, you're in first place, you don't need the added advantage, and everyone else has removed their autofire games. Second, I thought we were going to ban the GnG recordings that were point leeching. What happened to that? Lastly, Phil Lamat, out of courtesy to the other players, could you look over your recordings and remove the ones that are obviously sub speed. S'il vous plait. Ca me semble que la majorite des competiteurs ici sont sur que t'en as den .inps qui ne sont pas honnete.
That's all for me. Happy Holidays everyone,
Q.T.Quazar
(perpetually 4th)
qan@home.com
Posted: Sat Dec 18, 1999 12:30 pm
You don't like the acusations but then you acuse GK? We all want to
reduce the acusations and tgmame is the only way to do this, since it
will be more difficult to acuse someone of having a cheating tgmame
recording. (and getting closer on the autofire detection so there
won't need to be a reason to acuse or feel acused since the proof
will be in the recording, weather it uses a viewable banned technique
or has too low a framerate or has autofire signature button presses.)
Having the 75% score rule even forces acusations, it might even put
more pressure on someone to repeat a good score they might not truly
be able to repeat even to 75%. And if cheating did occur for some
games it might be easy to get 75% of a cheated score.... Just
letting people record tgmame recordings if they want to allows them
to record in a less acusatory forum, and those who want to keep their
origonal leaderboard scores they can.
i think that's 13 and a half cents by now...
churritz@cts.com
Posted: Wed Dec 22, 1999 12:30 pm
by German Krol
Ok QT :
Am I irking you???????????
"Remove your autofires recordings?????"
What recordings?, you mean "the recording". I'll be delete my
herbiedk score I don't have any problems.
I played it with autofire just to compare it with others players that
use autofire too.
I don't use my jostick ofently, I use only my keyboard in a 99% of my
recordings.I didn't cheat. I don't need to cheat and I don't want to
do it.
I don't even like this game, in fact I'm 8th in the hyprolym and I
really don't care.
It just isn't fair to accuse me like you did just because I used
Autofire in ONE GAME that, besides, I'd specially wrote in its
description "Autofire used".
Like you said "The spirit of gamesmanship here is dying".
I agree with you.
German Krol
germanc@netverk.com.ar
I think i'm at fault at putting the word "Acusation" in QT's mouth.
He didn't acuse GK of cheating just he didn't want autofire
recordings to compete with non autofirers. I think we all must
commend, praise, and award GK for actually stateing that he used
AutoFire in the description.
Having accurate labels of which recordings are autofire or not helps
the autofire detection development along nicely, Since it helps
create a test suite of as many autofire types recorded.
churritz@cts.com
