Tourney 2 - Time to decide on DIP Settings
Gameboy9
Post by Gameboy9 »
I need to figure out the DIP settings issue before too long so I'm prepared to establish DIP settings for the individual games when they are decided on. Therefore, I need your opinion on the DIP settings.
I think it's a REALLY good idea to do this: Look for TG Settings, hope we can find them, and if we can't, instead of doing the default settings, we'll use the hardest settings(except with lives, we'll use default or 3 lives, whichever is lower, if the DIP settings doesn't allow 3 lives or less, then we'll use the lowest one). If we do that, then there should be a near 100 %, or 100 % chance that TG recognizes the scores.
We'll use the normal voting rules for this issue. I await your opinions...
Thanks for reading :)
goldengameboy@yahoo.com
Barry Rodewald
Post by Barry Rodewald »
I personally would prefer using just default settings. Unless the
game is way too easy or way too hard on default settings, then that
should be what is used. My feeling is that if a game is set to a
difficulty that is quite high, then you can quickly lose interest in
it (unless you are very good at it, and let's face it, no-one is good
at every single game there is - except maybe BBH ;).
bsr@hn.pl.net
Aquatarkus
Post by Aquatarkus »
My vote is for doing it this way, but it'd be a good idea for you &
Pat to test the game out with the hardest settings first to make sure
it's still playable.
In other words, a par 5 548 yard dogleg with two sandtraps for an
18th hole is good, a par 3 848 yard double island where two drives
are made over large bodies of water and the "green" is a cup dangling
from a hot air balloon 50 feet above the ocean is not :)
Aqua
aquatarkus@digicron.com
Brian McLean
Post by Brian McLean »
Woohoo! Make it harder! HARDER!
Well, OK, maybe not. :) I'm all for hardest settings unless they're
somehow ridiculous as mentioned above. I do like the hard games, but
not if it gets to the point that any sense of accomplishment gained
by doing something correctly is squashed by the sheer amounts of
repetition you have to go through to learn a level/pattern.
But of course, that's a subjective thing. And probably subject to
~more~ votes. ;)
Brian McLean
bmclean84@hotmail.com
Dave Kaupp
Post by Dave Kaupp »
I'll agree on hardest unless the game is too hard to be enjoyable,
then drop down to TG settings if possible, then drop to a more
reasonable settings but no less than default of course.
info@kaupp.cx
