Hello.
I am attempting to use playback with the DOS Mame33RC.
I wanted to playback "vm_cclimber" which unzipped into a file called
"vm_cclim.inp". I then placed the .inp file in my Mame directory,
where I also have the playback.bat script. I then tried both using
the batch file (playback cclimber vm_cclim) and not using the batch
file (mame cclimber -playback vm_cclim) and in both cases, it just
brought up the game and I got no playback. How is this supposed to
work? Do I need the .inp file in some different directory?
hiwayman@infonet.isl.net
Playback doesn't!
JoustGod
Playback does!
Make sure you put your INP files in c:mameinp. The playback will be picked up from that directory.
JoustGod
pinballwiz1@msn.com
JoustGod
pinballwiz1@msn.com
