Well it started with me taking the lead - hey - I was the first person to ever lead the tournament - but we all knew I was going to lose it - BIG TIME
I think BBH took the next lead... held it for quite a while...
Then Q.T. took it over - again for quite a while - then BeeJay took it for a couple days, then Q.T. took it back again for another while
JoustGod takes over for a bit - then BeeJay went and played his least favorite game(I think) to retake the lead - and that's where we stand at this time... Seven lead changes by my count - BeeJay at the top, with 89 percent of perfect.(perfect = 372 points) JoustGod stands next with 88.45 percent, and Q.T. is third with 87.35 percent. All I can say is...... wow.
BeeJay is also leading the percentage battle - as he indicated earlier... 884.3 points - or 73.7 percent of perfect. Q.T. is next with 755.3 points - 62.95 percent, and JoustGod is third - 752.8 points - 62.75 percent.
I probably made a couple errors - especially in the lead changes bit...
You can also take a peek at the stats page for full coverage.
If you want me to pipe down(which you probably do
goldengameboy@yahoo.com
