Page 1 of 2
Raiden II(Germany) problem
Posted: Sun Aug 13, 2017 7:05 am
by PP.
I tried to watch BBH's RaidenII(Germany)-raiden2g inp but no chance.
Then I saw that this rom came out in mame184, while recorded inp claims mame181.
In mame181 menu exists "raiden2g", but under the title "RaidenII(easy version, Germany)" which is/was "raiden2eg"...
So, can someone fix this mess?
Re: Raiden II(Germany) problem
Posted: Tue Aug 15, 2017 11:55 am
by ***PL***
It is not confirmed, but if BBH used m181 instead of his claimed m188, then you are correct.
As of m184... raiden2g -> raiden2eg "Raiden II (easy version, Germany)"
Posted: Tue Aug 15, 2017 9:16 pm
by BBH
it's been replaced.
Posted: Wed Aug 16, 2017 7:21 am
by PP.
Innuendo will smash anything we do, but how do you start with the blue plane?
Posted: Wed Aug 16, 2017 4:51 pm
by Kale
Insert a coin then use the Seibu Code:
Up, Up, Down, Down, Left, Right, Left, Right, B, A
Posted: Wed Aug 16, 2017 5:41 pm
by PP.
Kale wrote:Insert a coin then use the Seibu Code:
B, A are the fire/bomb buttons?
I tried several times, but always get the red plane
Posted: Wed Aug 16, 2017 6:10 pm
by Kale
You aren't fast enough.
Posted: Wed Aug 16, 2017 6:17 pm
by PP.
Fast or slow, it doesn't work.
Posted: Thu Aug 17, 2017 7:54 am
by PP.
There is also something strange, you can't see his joy/buttons moves with the command "-iv 1".
There are no indications during his playback.
Posted: Thu Aug 17, 2017 8:15 am
There's a good reason for that. I'm sure you can figure it out, it's not hard.
Posted: Thu Aug 17, 2017 8:20 am
by PP.
mahlemiut wrote:There's a good reason for that. I'm sure you can figure it out, it's not hard.
Is it because he used blue plane?
Another strange thing is the "power up" in "Bubble Bobble: Lost Cave V1.0",
I saw his moves with "-iv 1" (left-right-left-right-1-2-1) but do not work for me!
Also, he just deleted his entry in "hyprolymba"...
Our friend is full of tricks
Posted: Thu Aug 17, 2017 9:32 am
You're missing the start button.
Posted: Thu Aug 17, 2017 2:25 pm
by PP.
mahlemiut wrote:You're missing the start button.
EDIT
Ok, I solved it. So, why the start button(1) doesn't appear?
Posted: Thu Aug 17, 2017 6:57 pm
It does, you just missed it.
Posted: Thu Aug 17, 2017 7:21 pm
by PP.
mahlemiut wrote:It does, you just missed it.
And what is the key for "start"?
I made a video to watch it slowly, it only shows <- -> <- -> 1 2 1
Do you want to see it?
Where/which is the 'start' indication?
