Sand Scorpion (Chinese Title Screen, Revised Hardware)
If the first place score only plays back to 125k? Why does it remain at over 600k?
- simpsons99
Arcade Game Scores
Arcade Game Scores
Re: Sand Scorpion (Chinese Title Screen, Revised Hardware)
helps to provide the marp link so people don't have to type in "Sand Scorpion" to the search page to try to find it to try to investigate and play it back again
http://replay.marpirc.net/r/sandscrpb
http://replay.marpirc.net/inp/1/4/c/pv_ ... olf146.zip
Rules say there must be three people who must report they can't play back a recording for it to be removed, after all if the recorders can be fallable so can the playbackers, why there should be three people to independently confirm it doesn't work since it's more likely the problem lies in the recorder if three verify their results.
So far it's you (if you reply and confirm that you tried to play it back and it doesn't) and me (in Feburary but now i only get 112700) that can't play it back. Thanks for bumping this, I must have forgot to start a thread since I can't find it anywhere else in playbackability. So now we need a third person to confirm it doesn't playback, then an editor will zero it (or if all three playbackers get the same score it will be changed to that score).
my results were as follows...
http://replay.marpirc.net/inp/6/c/f/snp ... olf146.zip
- http://replay.marpirc.net/inp/6/c/f/snpb_sandscrpb_303700_wolf146.zip
- 0001.png (18.03 KiB) Viewed 4451 times
- http://replay.marpirc.net/inp/1/4/c/pv_sandscrpb_635600_wolf146.zip
- 0000.png (18.9 KiB) Viewed 4451 times
I get 122700 with or without sound, no frameskip and frameskip 10.
