http://replay.marpirc.net/inp/f/f/4/guo ... olf125.zip
http://replay.marpirc.net/r/tetris
De-syncs very early and achieves only 174.
Gabriel.cn - tetris - 70,663
Re: Gabriel.cn - tetris - 70,663
I get the 174 points too. But I think it doesn't desync, I think it was recorded with nvram and the pieces were different.
Regards.
Regards.
Same interpretation (NVRAM required), different explanation.PeterPunk wrote:I get the 174 points too. But I think it doesn't desync, I think it was recorded with nvram and the pieces were different.
Regards.
nvram is most likely the case, get differing results with default and non nvram, zeroed.
*** All previous underneeth recordings had the same problem, all recorded with wolf125 and seemingly recorded with a default nvram (or there is an inherint playback issue with tetris.)
