Funky Jet
- simpsons99
Funky Jet
When the wolf 153 roms are added things will need to be changed .. Funky Jet World Rev 1 is now Funky Jet
Arcade Game Scores
Arcade Game Scores
Re: Funky Jet
also note, the recent protection fixes changed the last round transition slightly, not sure it affects actual gameplay, but you should be aware of it (if it does affect gameplay then old scores should probably be 0'd)
- simpsons99
Re: Funky Jet
I do not know what your speaking ofHaze wrote:also note, the recent protection fixes changed the last round transition slightly, not sure it affects actual gameplay, but you should be aware of it (if it does affect gameplay then old scores should probably be 0'd)
Arcade Game Scores
Arcade Game Scores
Re: Funky Jet
after completing world 6 the emulation in old versions of MAME would take you back to a glitched 'world select' screen to choose the 7th level, but there was no 7th level to choose. after a while the game would continue.simpsons99 wrote:I do not know what your speaking ofHaze wrote:also note, the recent protection fixes changed the last round transition slightly, not sure it affects actual gameplay, but you should be aware of it (if it does affect gameplay then old scores should probably be 0'd)
with the fixed protection emulation the game puts the extra levels straight after the world 6 levels with no break.
