Do we add a special rule advising that you must use version 0.153 or greater, once 0.153 inclusive of Barry's patch has been released, and archive the previous scores that were achieved with an incorrect emulation of the left/right firing controls?
Do we just leave the existing scores, but put in a note that they were achieved on a version of Mame that had incorrect emulation of the left/right firing controls?
My feeling is that this is effectively fixing a bug in the emulation and the previous scores should probably be archived, but that's the purist in me speaking so I'd be interested in what other people think.
Here's some quotes from the discussions on the incorrect emulation of the firing controls: viewtopic.php?f=10&t=15273#p58969
xelnia wrote:I think there is an issue with the emulation of Tutankham that needs to addressed. The arcade version of Tutankham is equipped with two joysticks, and one of those joysticks is a 2-way used for firing the laser either left or right. This means that a player can only fire in one direction at a time. However, in MAME, it is possible to fire in both directions simultaneously. The default mapping for the firing controls are Ctrl for left and Alt for right, so pressing Ctrl+Alt will result in a simultaneous left+right firing of the laser. This can provide an advantage for a player who is in a very rough spot. I'm not sure if this kind of situation is covered by the MARP rules, since the default controls allow this.
mahlemiut wrote:Clearly, the driver isn't set up as a dual joystick, as MAME does not allow opposing directions of a joystick to be pressed simultaneously.
