wolf106 command line
kernzy
Post by kernzy »
hey guys,
i recently tried to use command line on a wolf 106 inp, but i could not get it to work doing what i know works.
do i need to do something different?
the normal commands do not work...
cheers!
Re: wolf106 command line
Bit more info would be helpful.. like the commandline you're trying to use, and the output you get.
kernzy
Post by kernzy »
i'm doing exactly the same as i do when using modern wolfmame's.
i got it to work just now, typing "record kungfum kungfum", but when i type "mame kungfum", i get "mame is not recognised...."
i experience this with other older mame's, it's like some of them require a different 1st word, instead of "mame" for common commands...
The name of the executable was not "mame.exe" for the v0.106 version of wolfmame, rather it is called mamep106-vc.exe.
So, instead of typing mame kungfum at the command prompt you would type mamep106-vc kungfum
So the lesson here would be - learn to use the 'dir' command, or learn to use Windows Explorer.
kernzy
Post by kernzy »
cheers guys!!
i did try what Beejay said, but i did it wrong. i typed "mamep106gui-vc kungfum". DUH!! or should i say, "DIR"!!!
Thanks for the advice gents!
i have fresh issues. 3 days ago, my computer crashed, taking about 2 years of downloads/programs with it. lost most roms, artwork, etc. now, i am failing to get wolf150 and 151 to work!!
don't know why. i will figure it out.
8)
