Elevator Action
- ballas
- MARP Knight
Elevator Action
Here at MARP with what is the playing difficulty? I have messed around with the different TG variations in the past and just want to set it right again. Is it Normal settings?
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
Koos van Dyk
Johannesburg
SOUTH AFRICA
Re: Elevator Action
why not simply delete the .cfg and .ini files?
if the emulator asks you to type ok,
then it has been reset .
Re: Elevator Action
There is no special rule. So you can set what you like. I think many recordings are done on Easiest.ballas wrote:Here at MARP with what is the playing difficulty? I have messed around with the different TG variations in the past and just want to set it right again. Is it Normal settings?
- ballas
- MARP Knight
Re: Elevator Action
Thanks guys. It would be nice to see the description of the difficulty played on in the message line.
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
Koos van Dyk
Johannesburg
SOUTH AFRICA
