Night Raid
Posted: Sun Nov 10, 2013 8:44 pm
not getting this CHD game to playback correctly with or with out default diff/nvrams.
http://replay.marpirc.net/inp/8/a/a/prf ... olf150.zip
http://replay.marpirc.net/r/nightrai
Re: Night Raid
Posted: Tue Nov 12, 2013 4:17 pm
by Fordy
Well I'm not having much luck with these chd games. Before I record them I delete cfg, diff and nvram and then after I finish the recording I delete them again to check the game plays OK and it works every time, although obviously I'm doing something wrong somewhere. Thanks for trying anyway Skito.
Re: Night Raid
Posted: Tue Nov 12, 2013 5:22 pm
Thanks for testing. Unfortunately some playback problems will playback good the first time but then never playback again. Sometimes just due to a timing issue. It might be good to play it back a day later, but that's hard to do a lot of the time :). If it is working for you perhaps I'm doing something wrong or there is some difference. Does your rom pass the audit tests for mame150 (no bad crcs) ?
Re: Night Raid
Posted: Sat Nov 16, 2013 7:20 am
by Fordy
Well I just tried playing it back again and it works fine. I don't think there is any problems with the chd, where I got it from said it was a 0.150 chd and I also downloaded an up-to-date Taito GNET bios just to make sure my old one wasn't the problem. I am using a gui and I don't suppose that could be the problem could it?? I don't seem to be having much luck with these chd games which is a shame as I really enjoy playing them.
Re: Night Raid
Posted: Sat Nov 16, 2013 2:42 pm
repeat playback is a good sign, there must be something that I don't have set that you do. I'll keep trying.
Re: Night Raid
Posted: Mon Nov 18, 2013 4:13 pm
by Fordy
As a matter of curiosity have you played the game? And if so can you get any of your scores to play back?
By the way if you can't get my inp to play back then don't worry about it, it's not that good anyway, I have a much bigger score recorded.
