- 0.149u1: Alex Jackson reorganized Outzone sets and improved descriptions. Fixed dipswitches and inputs (after verification of the M68000 and Z80 code) in outzone and clones. Tagged Out Zone (oldest set) Z80 ROM as BAD_DUMP and the set itself as GAME_IMPERFECT_SOUND after discovering that this clone's M68000 and Z80 ROMs are almost certainly mismatched, causing wrong sound effects. Added 'Test Switch' dipswitch. Changed clone (set 4) to parent 'Out Zone' and 'Out Zone (set 1)' to clone (harder), (set 2) to 'Out Zone (old set)', (set 5) to 'Out Zone (older set)', (set 3, prototype?) to 'Out Zone (oldest set)'. Renamed (outzone) to (outzoneh), (outzonec) to (outzone), (outzoneb) to (outzonec) and (outzoned) to (outzoneb).
- 0.104u5: Tormod Tjaberg added Out Zone (set 1). Changed 'Out Zone (set 1)' to clone 'Out Zone (set 2)' and clones 'Out Zone (set 2, prototype?)' to 'Out Zone (set 3, prototype?)' and 'Out Zone (set 3)' to 'Out Zone (set 4)'. Renamed (outzoneb) to (outzonec), (outzonea) to (outzoneb) and (outzone) to (outzonea).
- 9th December 2005: Corrado Tomaselli dumped Out Zone (set 4). This dump comes from a totally dead board with no original stickers. They aren't very different from the set 1 , so they can be hacked or a little corrupted. I swapped the roms on my working board and they seem to be good but maybe it crashes on later levels. In my opinion set 2 has to be renamed to "protoype" or "early version". There are less music/sfx there isn't an ending sequence. I dumped 4 outzones and they were all set 1.
- 0.97u5: Aaron Giles swapped Out Zone (set 1) with (set 2) - the other set was a newer revision with more secret bonuses, refined sound effects and a real ending instead of a few text lines. Renamed (outzone) to (outzonea) and (outzonea) to (outzone).
- 0.37b13: Changed description to 'Out Zone (set 1)' and clone '(bootleg)' to '(set 2)'. Renamed (outzonep) to (outzonea).
If I correctly understand, there have been three major swaps, which have taken effect in MAME98-MAME105-MAME150
the versions seem to have evolved with this pattern:
previous -> MAME98 -> MAME105 -> MAME150
outzone -> outzonea -> outzoneb -> outzonec
outzonea -> outzone -> outzonea -> outzonea
-> outzoneb -> outzonec -> outzone
outzoned -> outzoneb
outzone -> outzoneh
Sawys' 1,244,010 outzone@wolf83 should go to actual outzonec.
Ace13's 3,190,700 outzone@wolf106 should go to actual outzoneh
and so on. Is it correct?
