TimeTrial 2013 - R1 - Out Zone (1 loop) [outzone]
Moderator: giro-X
RAX
Post by RAX »
Image Image
Here we are with the first game of the TimeTrial 2013, Out Zone, a great vertical shooter from Toaplan, year 1990.
This game has infinite loops, and is quite short, so it's ideal for our needs. It's also the main reason for having switched to WolfMAME150: its romset has been reorganized. On Wolf149 I found a rather difficult game under default settings, even first enemies took two bullets to die, and they fired quite a lot. From my memory, that difficulty was in loop2+, in fact I initially thought to let you play a clone. But with new WolfMAME150 the parent romset has changed, and the old parent was indicated as harder. Actual parent romset is at an adequate difficulty under normal/default settings.
Commands are simple: joystick 8-way, button1 shoot, button2 bomb.
Ok, after some technical notes let's talk a litte bit about this nice game, when you'll get the purple energy ball you'll really discover how funny it can be. Until you'll find the flame item exactly on your path. That won't be that funny, but don't worry, it's very powerful too ;) .
Usually this game is played for score with many bombs in stock, to get the 5K bonuses, but in this tournament you will bomb-walk quite often, I guess.
Remember: Wolfmame 150 and default settings. The requirement in this tournament is the first loop, play it as fast as you can, because your goal is to complete the first loop in the less time possible.
Round Duration: Sunday October 27th, 00:00:00 GMT - Saturday November 2nd, 23:59:59 GMT
TIME REMAINING
Here are some useful links, the correct Wolfmame to use and the batch files I promised to the players that aren't familiar with command-line MAME.
This is a vertical screen game, and some people (like me) usually turn their laptop on its side to play fullscreen. If you are going to do this, take the second batch pack.
Wolfmame 150 - Batch files for this game (horizontal screen), (vertical screen)
There are 3 batch files inside each zip:
Play.bat (normal play without recording, you can train with pause or savestates)
Record.bat (to record a new inp, keeps backup of the previous recording)
Replay.bat (to see the last recorded inp)
Good luck to everyone participating, and now run!
RAX
Re: TimeTrial 2013 - R1 - Out Zone (1 loop) [outzone]
Post by RAX »
FINAL Scoreboard
1 - (Stage7) 42.083 frames [12min 11sec] - TRB_MetroidTeam - download - Ok - 25 pts
2 - (Stage7) 45.037 frames [13min 02sec] - nii-san - download - Ok - 20 pts
3 - (Stage6) 39.525 frames [11min 26sec] - Giro-x - download - Ok - 16 pts
4 - (Stage6) 44.814 frames [12min 58sec] - Krj - download - Ok - 13 pts
5 - (Stage6) 54.692 frames [15min 50sec] - Franco Benedetti - download - Ok - 11 pts
6 - (Stage6) 55.067 frames [15min 56sec] - Chrono256 - download - Ok - 10 pts
7 - (Stage5) 33.220 frames [09min 37sec] - Sawys - download - Ok - 9 pts
8 - (Stage4) 26.616 frames [07min 42sec] - Paulo Valmir - download - Ok - 8 pts
9 - (Stage3) 13.436 frames [03min 53sec] - Shahbaz - download - Ok - 7 pts
10 - (Stage3) 14.232 frames [04min 07sec] - Kernzy - download - Ok - 6 pts
11 - (Stage3) 15.584 frames [04min 31sec] - Beejay - download - Ok - 5 pts
12 - (Stage3) 16.394 frames [04min 45sec] - SFCHAMPION - download - Ok - 4 pts
13 - (Stage3) 16.701 frames [04min 50sec] - BDFil - download - Ok - 3 pts
14 - (Stage3) 18.251 frames [05min 17sec] - Colman Paolo - download - Ok - 2 pts
15 - (Stage3) 22.726 frames [06min 35sec] - Agodzilla - download - Ok - 1 pt
16 - (Stage2) 11.373 frames [03min 18sec] - KrazyKongFan - download - Ok - 0 pts
17 - (Stage2) 13.748 frames [03min 59sec] - DaLar - download - Ok - 0 pts
18 - (Stage1) 7.159 frames [02min 04sec] - Phil Lamat - download - Ok - 0 pts
RAX
Post by RAX »
Important rule clarification, just in case I haven't been clear in the rules:
it' not mandatory to complete the requirement (also called somewere 'goal') of the turn to participate. In other words, you don't necessarily have to finish the first loop to send your INP: for example, if you reach stage 5 only, you can still upload your progress, and with the rule explained in the other topic you'll enter the TT scoreboard with the time of stage4.
Another thing (thanks TRB for the suggestion): Please use in the description the word TT2013 instead of TT13 I suggested you yesterday, because in the future it could generate confusion in board searches with Tournament T13.
RAX wrote:Another thing (thanks TRB for the suggestion): Please use in the description the word TT2013 instead of TT13 I suggested you yesterday, because in the future it could generate confusion in board searches with Tournament T13.
Hi all! Thanks for inviting RAX!
1st try = http://replay.marpirc.net/inp/b/0/0/trb ... olf150.zip
TT2013 - St2ok = 11096 (11542-446)
About the regular submissions to MARP, let me know if it works for you.
http://replay.marpirc.net/index.cgi?mod ... xlines=500
RAX
Post by RAX »
TRB_MetroidTeam wrote:About the regular submissions to MARP, let me know if it works for you.
It works, thanks.
First scoreboard updated, very cool stage1 Valter :)
ballas
Post by ballas »
I will most probably be out. DOn't have the wolf 0.150 roms.
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
Krj
Post by Krj »
Is this correct?
http://replay.marpirc.net/inp/d/e/1/krj ... olf150.zip
[TT2013: Stage 3 completed in 16400 (I think) Total 21500]
RAX
Post by RAX »
Yes, it's correct, and in the scoreboard now, just a little trim in the framecount.
Thanks for the informations you guys are adding to your submissions, this speeds up my work, carry on.
Hi.
Here is one of my first games recorded today since a long time but it's clear that this version has the same settings in comparison with the parent rom i played with wolfmame in... 2004 !! Almost 10 years ago :mrgreen:
Stage 2 cleared.
I don't know if i will have time to play seriously so i play at least for fun :-)
Good luck to everyone.
outzone-sawys-stage 2 ok-w150.zip
(163.05 KiB) Downloaded 1338 times
RAX
Post by RAX »
Scoreboards updated, welcome Sawys.
sawys wrote:Here is one of my first games recorded today since a long time but it's clear that this version has the same settings in comparison with the parent rom i played with wolfmame in... 2004 !! Almost 10 years ago :mrgreen:
Yea it's true, the harder version seems to be appeared in MAME105 as brand new parent romset, now renamed in outzoneh.
I've opened a new topic to discuss this rename thing, My opinion is that many old recordings should be moved to different romsets
SFCHAMPION
Post by SFCHAMPION »
Hi!
I'm in too ! ^_^
3rd boss destroyed
Frames 19600 - 470 = 19130
sfchampion_outzone.zip
(299.6 KiB) Downloaded 1317 times
http://replay.marpirc.net/inp/4/8/e/trb ... olf150.zip
TT2013 - St5ok = 31992 (32428-436)
PS.: I'm counting the 1st frame that you get the score for beating the boss. And starts when the life meter appears on the screen.
Hey, it seems the forum time is 0h30 different than my real time.
I'm GMT-3, but DST is in effect now, so I am with "GMT-2".
It's 10:49PM here, but this post is stamped 11:19PM (I'm logged in), so forum is showing 30 minutes in advance of my real time. Please confirm if it's happening with other players too.
It may be confused with the deadline if submitted here in the forum.
Edit: and comparing forum time with this site ( http://24timezones.com/ ), forum is 31 or 32 minutes in advance.
