http://replay.marpirc.net/inp/3/2/3/ppk ... olf147.zip
this game does not even rack-up a credit
too bad 'cause this one is tough.
i scored 8800
can someone check these ?
space ranger
Re: space ranger
Re: space ranger
one more try will be three strikes
simpson or kernzy ?
simpson or kernzy ?
Re: space ranger
you gotta be kidding me?????????
it took ages to get that score!!!!!!!!!!!!!!
Re: space ranger
does this one work?
have a butchers, let me see where the problem lies...
- spacerng.zip
- (156.2 KiB) Downloaded 253 times
Re: space ranger
and then please try this one....
cheers!
cheers!
- spacerng2.zip
- (36.59 KiB) Downloaded 242 times
Re: space ranger
spacerng.zip playsback to 3640
spacerng2.zip playsback to 850
http://replay.marpirc.net/inp/3/2/3/ppk ... olf147.zip never starts
Tar's 8k playsback ok.
Re: space ranger
ok, so they both work, then.
so the one in question should also work.
i don't know what happened, and i've deleted the original file!!!
cheers Skito!!!
your help is welcomed.
cheers Skito!!!
Re: space ranger
recordings only work if they work, this one doesn't, yet. you should test your recordings before uploading is the moral of the story. I thought it might be if you deleted the BAD DUMPS from the rom but mame doesn't let you play it back if it's gone, maybe if your bad dump roms are bad, but in that case all recordings probably wouldn't work and some do.kernzy wrote:so the one in question should also work.
