I keep getting this message when trying to submit a score
simpsons99
Post by simpsons99 »
some kind of error with the zip file - couldn't unzip it
command: './exe/unzip -l bea99_mirax_51520_wolf146'
correct the bad stuff and resubmit, or whinge to Zwaxy
something happen to the site again.. I'm not doing anything different that would cause this to happen.
Arcade Game Scores
simpsons99
Re: I keep getting this message when trying to submit a scor
Tryed with a different verson of mame and i'm getting the same message.
Mirax (set 1) score 69,420.zip
(80.59 KiB) Downloaded 558 times
Arcade Game Scores
It seems to unzip okay for me (standard Linux unzip, pretty much the same as the scripts use), did you try it again?
It is also useful to note that using 7-zip to create zip files is a bad idea, as it often uses compression methods that some zip programs (including MAME itself) don't support.
simpsons99
I've tryed it many times.. The Set 2 scores i uploaded it tolk a few different recordings before it submited the score.
I'm doing the samething i've allways done.
I've tryed other games and i'm getting the samething.
Thought it might have something to do with the Leader board being broken. Seems like a fight to submit anything .
I really don'nt know what to do next.
Arcade Game Scores
simpsons99
just tryed it again.. Samething .. It is like it does'nt really try quickly goes to that error screen.
Arcade Game Scores
Hmm... sounds like unzip isn't working for some reason... can check if it is at least still there... ok, it is. Strange... Probably need to summon Zwaxy for this one.
EDIT: Uploaded a quick INP, works fine for me, so no idea how you get that sort of error with yours.
simpsons99
Just tryed again.. Samething
There is nothing different to my recordings I'm trying to Submit.
I just don'nt get it..
Arcade Game Scores
Having the same problem here. New error with the scripts? If it isn't one thing it's another...
simpsons99
BBH wrote:Having the same problem here. New error with the scripts? If it isn't one thing it's another...
Nice to see someone else is having problems with this... I was really starting to get the feeling it was just me.
I was able to slip alot lower score on the board.
There is not different then the other recording that i can tell..
I would hate to get a Millon on DKJR and it not let me Submit my score... Thank goodness this all happened after my 10 millon on Dark Tower!
Arcade Game Scores
Fordy
Post by Fordy »
Don't worry Brian you aren't the only one getting this message, but I'm sure it'll get sorted.
simpsons99
I'm hearing from others ... I was wondering if the Windows update caused this .. I tryed doing a system restore back.. Got same error message.. Did window's update again .....
Arcade Game Scores
I highly doubt Windows Update would have any bearing on the server deciding to take your recording or not...
simpsons99
Figures he gets 2 scores through that beat my scores.. But i have 2 scores higher but it will not submit them.
This just is'nt fair theres nothing wrong with my recordings.
Mirax (set 2) score 67,540.zip
(98.43 KiB) Downloaded 544 times
Arcade Game Scores
I understand your frustration but a lot of people can't upload recordings right now. Not being able to submit a recording at this moment in time is not the end of the world.
simpsons99
Yes i know and understand this.
Why are show submits getting through and others are not.
Arcade Game Scores
