spacefbe2
spacefbe2
http://replay.marpirc.net/inp/6/e/3/bea ... olf106.zip
only plays to 8,000
also the 16,000 game only to 13,000
both of skito's games played back to advertised amounts
Re: spacefbe2
I also get this result. I think this is because of the new sample file. I haven't downloaded/found it. There are new samples for space fire bird somewhere. And if you have this file in your samples directory when playing these back, i bet it would work. Samples usually affect playback for old mames, but I thought newer mame would be better about this, maybe same goes.
Re: spacefbe2
http://replay.marpirc.net/inp/2/1/8/bea ... olf146.zip
this is the one that would not playback
i may have been mistaken about the first post.
you say it is because of the sound samples.
i agree , i used -nosound
also, bea99's wolf106 recordings work & his wolf146 don't work
simpsons99
Re: spacefbe2
Post by simpsons99 »
I do not use sound samples .. in space firebird.
Arcade Game Scores
Re: spacefbe2
woah, then there is a serious problem, your inps aren't playing back for either of us which means it's two strikes against you. Hmm I will try again maybe there's an nvram or other sound issue.
Re: spacefbe2
skito wrote:other sound issue.
been meaning to try his 28k recording 'with sound'
the basic sounds of birds are there minus fire and explosion
Re: spacefbe2
Could this be another game where any automatic frame-skipping will now muck-up the playback, similar to some of the early 80s Sega games?
simpsons99
Re: spacefbe2
maybe becouse this is a new rom in Wolf146? I will try it in Wolf147 later
Arcade Game Scores
simpsons99
Re: spacefbe2
I forgot i did a restore on my puter .. I would have to get this rom again. My Luck one of the roms sites is having problems. Hopefully i can get this rom again.. I still have'nt found the other one i used to have that dissappreared.
Arcade Game Scores
