B-Wings Rom Sets Wolf106
simpsons99
Post by simpsons99 »
I don'nt know when it happened but there was a Rom name change that happend after Wolf106.
I think it should be noted since most people use this verson for both here and TG .
Confusing on which one is which with that verson.
Arcade Game Scores
Re: B-Wings Rom Sets Wolf106
Yes, bwings in 0.106 is now bwingsa in 0.146. Don't know when it was changed, but it was certainly before 0.126, and I can't find any logs of it as far back as the beginning of 2008 (0.121).
Maybe people need to use something that isn't 6 or 7 years old... ;)
simpsons99
mahlemiut wrote:Yes, bwings in 0.106 is now bwingsa in 0.146. Don't know when it was changed, but it was certainly before 0.126, and I can't find any logs of it as far back as the beginning of 2008 (0.121).
Nothing wrong with Wolf106 they just added alot of different slot games and others since then... Changed Roms names that did'nt need to happen .
Arcade Game Scores
simpsons99 wrote:they just added alot of different slot games and others since then...
Which has what to do with anything?
simpsons99 wrote:Changed Roms names that did'nt need to happen .
Only changed to accommodate the two clones added after 0.106. Parent sets are always the most recent version.
0.111u6: Changed 'B-Wings (Japan)' to clone 'B-Wings (Japan old Ver.)' and clones 'Battle Wings' to 'B-Wings (Alt Ver.?)' and 'Battle Wings (alt)' to parent 'B-Wings (Japan new Ver.)'. Renamed (bwing) to (bwingso), (bwings) to (bwingsa) and (batwings) to (bwings).
This said, I've moved pre-0.112 inp from (bwings) to (bwingsa) and added special rules for actual bwings.
Actual bwings should be playable under wolf106 using short name = "batwings" though.
Ah, there we go, changed stupid clone naming to something more sane. :)
simpsons99
Phil Lamat wrote:0.111u6: Changed 'B-Wings (Japan)' to clone 'B-Wings (Japan old Ver.)' and clones 'Battle Wings' to 'B-Wings (Alt Ver.?)' and 'Battle Wings (alt)' to parent 'B-Wings (Japan new Ver.)'. Renamed (bwing) to (bwingso), (bwings) to (bwingsa) and (batwings) to (bwings).
TY Phil
Thats really confusing on which one to use with wolf106 .. If you ask me they play better on Wolf106
batwings is Broken in wolf1o6
Arcade Game Scores
Post by ***PL*** »
There was indeed a problem with bwings getting renamed to bwingsa. I'm having Phil undo the INPs that he moved. All should be OK after that.
simpsons99
***PL*** wrote:There was indeed a problem with bwings getting renamed to bwingsa. I'm having Phil undo the INPs that he moved. All should be OK after that.
what was the problem with the changes?
Arcade Game Scores
I don't understand what happened there : all the inputs I've moved from (bwings) to (bwingsa) are again under (bwings).
Plus the special rule I've wriiten for (bwings) is now at (bwingsa).
What do you want me to do, Pat ?
Move the Locutos/Rossi/krf/pacman inputs from (bwings) to (bwingsa) again ?? to swap again ?
Post by ***PL*** »
OK this is complicated in a couple of ways, but I see what happened. Phil created special rules and INPs got moved and then I made some MAME name changes that impacted everything Phil had done.
I needed to back out the changes Phil made and then apply mine.
Right now what needs to be done is apply Phil's changes as originally intended. That is, create special rules for the new parent and move the pre-m112 INPs from bwings -> bwingsa
Let me do this and then we can test to see if all is good.
simpsons99
***PL*** wrote:OK this is complicated in a couple of ways, but I see what happened. Phil created special rules and INPs got moved and then I made some MAME name changes that impacted everything Phil had done.
I really don'nt know what happened here.. My Inps got moved from the different versons and theres no record of this happening?
I belive the 50k one is in the wrong one now?
I was told in the other post before that the B-Wings was the Alt one in Wolf106? But it was moved to the New Japan Verson? belive this is where the 50k one should be?
Arcade Game Scores
If you used MAME 0.112 or later, and used bwings, then it should remain in bwings.
If you used MAME 0.111 or earlier, and used bwings, then it should be in bwingsa.
simpsons99
This is a bwings Recording
B-Wings (Alt Ver.?)
(bwingsa) simpsons99 (@) 16 Jun 12
03:15:29 50,190 (edit) wolf145
get MAME
Arcade Game Scores
