Missile command
Dave Kaupp
Missile command
Post by Dave Kaupp »
How do I speed up the mouse in missle Command? I keep rolling off the mouse pad.
Also, is this OK to submit scores if I change the mouse speed?
info@kaupp.cx
Zwaxy
Post by Zwaxy »
You hit the 'TAB' key, then go to 'analog setup' and use the cursor keys to change the numbers you find there. Doesn't help much, but that's how you do it...
It's fine to submit scores with whatever mouse speed you like.
Chris.
zwaxy@bigfoot.com
Dave Kaupp
Ok, it looks like I wa in the correct menu. I changed all the
settings in anouloge, but the mouse speed apperas to be the same.
I'm using W32.35r2
info@kaupp.cx
Aquatarkus
Post by Aquatarkus »
Maybe with the windows MAME you have to change the global mouse
settings in the Control Panel? The analog menu also controls the
keyboard response for spinner/trackball games - usually it's not so
good but it's there.
Aqua
aquatarkus@digicron.com
david oliver
Post by david oliver »
set the trackball size to large youll notice a big difference (i was
able to get 40k with this compared to ~20k with mini)
cartman@solanobiz.net
