http://replay.marpirc.net/inp/f/0/b/rg1 ... olf106.zip
http://replay.marpirc.net/r/720r1
This may need a later version of mame, but there must have been some reason negative1 used an earlier version. Goes out of sync just after 1rst half pipe.
720
Re: 720
Plays fine here.Chad wrote:http://replay.marpirc.net/inp/f/0/b/rg1 ... olf106.zip
Re: 720
720 seems to work ok in this version..
currently.. i'm rotating between 106 (because thats what TG uses)..
wolf130... another popular version.. and wolf136.(the latest)..
some games have problems in the later versions..
i suck at 720! I've tried playing back the better scores to learn,
but most of the older ones don't work..
i can get mame to boot, but i get a 'cant initialize display' error...and it quits
(this happens with 'escape from the planet of robot monsters' replays also -> running
under DOSBOX in vista)..
there's some good videos on youtube to watch..
but the controls are too hard with the current settings..
i'll have to play around with them..
later
-1
later
-1
Re: 720
It's ramp, not half-pipe. You've been watching too much Olympics.Chad wrote:Goes out of sync just after 1rst half pipe.
negative1 wrote:but the controls are too hard with the current settings
Mamedev forked it up when they removed mouse support to emulate the "original hardware"...It's unplayable with joystick - not a single person in the world has an original 720º joystick hacked to a PC.
