Need to re-upload a score.
Larcen Tyler
Post by Larcen Tyler »
I forgot to delete the NVRAM before recording, so I need to reupload my score. Should I just submit it like normal, or edit the score and then submit?
Larcen Tyler
Some Eternal Champions just never die
Re: Need to re-upload a score.
If the score is higher than your previous one, it will automatically take over from that. If the score is the same or less, then select a different (higher) score and edit it back afterwards.
Post by ***PL*** »
mahlemiut wrote:If the score is higher than your previous one, it will automatically take over from that. If the score is the same or less, then select a different (higher) score and edit it back afterwards.
I don't think that will work!! After lowering the score, the 1st submission will still have the higher score...
The best way would be to rename the 1st submission to *deleted and then upload the 2nd score.
This did work, maybe not on the new system, but in the past you could submit with a score one higher and then edit it back to the shared score and the newer recording would supercede the older one, i think. but deleting and resubmitting will also work.
