K7 - Round 1 - Part 3 - Tumble Pop (tumblep)
ZeroMax
Re: K7 - Round 1 - Part 3 - Tumble Pop (tumblep)
Post by ZeroMax »
My previous K7 replay :P :D .
8 x 1 up - 1 more than target D :)
Rainbow Diamonds x7
1CC
100k points failing from last boss :S (BUG ?)
zeromax_tumblep_1053500.zip
(97.7 KiB) Downloaded 373 times
RAINBOW CRYSTALS Image are on stages:
Asia - 4, 7
Africa - 4
America South - 8
Antarctica - 8
Australia - 6
Cosmos - 2, 9
News in my web page :
1 - Now, page have 2 sheets in the same page :
- ROUND 1 - CUMULATIVE
- ROUND 1 - PHASE 3
2 - Like Gemant seems to have no time to update the leaderboard, i made an update of my leaderboard with unconfirmed scores sended until today 20:52 GMT.
I hope i don't make errors, but only coordinators will give the real results.
I think that this update will encourage to participate and see if there is a chance to go to round 2 or 3 for the best ;-)
Problems with the following replays:
DIX - 154,400 - This replay was recorded with the "tumblepj" romset instead of the required "tumblep" romset. DIX, please switch to using the "tumblep" romset as specified in the rules for this game.
SFCHAMP - 543,700 - This replay was submitted more than 48 hours after it was recorded which is a violation of the K7 rules. In addition, while it plays back to the advertised score, in the description it states "Target A", but it does not score at least 10,000 pts on the first stage (it only scores 4,800 on the first stage).
JoshF - 1,006,900 - This replay plays back to the advertised score and reaches Target C, however in the description it also states "Target A". It does not reach Target A, since it does not score at least 10,000 pts on the first stage (it only scores 4,600 on the first stage).
-George
JoshF
Post by JoshF »
I thought the rainbow crystals were worth 10.000 for some reason and I got one so I thought I achieved target A.
EDIT: Oh, you mean like the first floor. So it's basically a "don't pick Russia first" target. I'll need to figure out how to do that, but the Karnovs get crazy as the final world level.
For 10k on first stage you must select Africa only.
flutotal
Post by flutotal »
Rio de Janeiro Stage is great!! \o/ :D
ballas
Post by ballas »
destructor wrote:For 10k on first stage you must select Africa only.
yes this was a very clever choice of game because if we want Target A we all have to follow the same route in the game.
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
UPDATE TODAY AT 16:06 GMT
INNUENDO
Post by INNUENDO »
Sawys, good job! Now it´s possible to understand better the champs! Thanks! :P
INNUENDO wrote:Sawys, good job! Now it´s possible to understand better the champs! Thanks! :P
Thank you :-)
Up today at 16:43 :-)
ballas
Post by ballas »
Thank you :-)
Damn, it sucks being 36th with 2 days to go #-o
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
RAX
Post by RAX »
Hi Sawys,
I think there are some errors in your actual page
-21th position worths 80pts instead of 85, and all worst positions have a -5pts offset. You (Sawys) get 105 instead of 110pts, Innuendo 100 instead of 105 and so on
-Massimiliano and Beejay have the same score/target, but different points
-Atomo gets 1pt (instead of minimum 5)
thanks again you for your page and patience 8)
RAX wrote:Hi Sawys,
Thank you :-)
Corrections done but not in line for the moment !
- The 21 problem was because i put 22 instead of 21, 23 instead of 22... It was a bad manipulation from me yesterday ^^ . Corrected.
- the massimilano and beejay was again a fault because pf manual manipulation... The automatisation is on the definitive rank. Corrected.
- about atomo, i erased the formula with the 1 of the target A. Corrected.
Thank you to give me the info !
UPDATE ON 16 Oct 08 15:56 GMT
