pc_trjan - leeching issues
powerman7t
Post by powerman7t »
There is a place in pc_trjan (2nd vertical stage, where you go down the tubes), that if done properly, you can suicide after doing this over and over again. You can do this by getting the 1up on the second batch of yellow things, then on the final floor before you drop to the bosses, there is a moving thing that if you whack and collect the star, you get 10k. If you didn't knock off the bomb making yellow thing, suicide by hitting the red balls that drop and roll on the floor.
I am sending my INP of 210k+ to MARP right now. I did this trick 6 times (actually succeeded 5 times).
On the NES, I stopped at 1 million using this trick, and I could max it out if I spent the time.
Should this be banned or limited any or this is not an issue?
Re: pc_trjan - leeching issues
I'd say that's something that ought to be banned, since it can be done infinitely.
