wow
wow
http://marp.retrogames.com/inp/3/5/1/go ... olf106.zip
Anybody else tried to play Jockel Gockel's Wizard of Wor?
Not going anywhere for me at all.
Playbacks normally here. Used f10 after couple minutes of watching.
1100, first time, 100, second time, 300, third time, looks like we have a m63 like issue.
If that bears any difference, I used gui version. First downloaded roms, then tried if they work starting the game and exiting after few seconds, then playbacked. I was downloading stuff in the background...
WinXP SP2
P4 2,4
Chad wrote:1100, first time, 100, second time, 300, third time, looks like we have a m63 like issue.
Except the .63 bug didn't result in inconsistent results like that. One set of systems would play the recording correctly, the other set of systems would play the recording to the same incorrect result.
I'm using Vista, FWIW.
Plays back normally for me on my laptop (XP Pro, SP2) without needing to take any special steps.
The input file playsback for me also.
this person walks around the maze with real authority
Wolfmameplus 106gui-vc
windows xp
compatibility mode off.
new score on up page 326,100
i have not watched it .
Re: wow
plays back to 319000 for me.
I think this game has sound samples. I have NONE installed. If you have sound samples installed for wow, remove them or deactivate use of samples and try playing it back again.
there is still an issue with mame/wolfmame on playback if same sound samples weren't used for some games.
btw, I also went ahead and played back Sackville's new score just posted too...someone else beat me to confirming. :P
so both played back to posted scores.
Re: wow
duplicate....
Sackville's 326k plays fine.
Anybody have any idea who these guys are? Odd that we have two guys submitting world-class scores on this particular game as their only MARP entries.
tar wrote:this person walks around the maze with real authority
If I had a laser cannon I'd walk around with authority too.
both playback fine for me now with "-nosamples". I couldn't play either with -samples. This appear to be the same person recording twice, but i can't prove it, other than the fact the techniques and sniper waiting spots are similar.
This game is better with samples btw...
jtc wrote:If I had a laser cannon
good point
ceh wrote:same person recording twice
i think that as well
both recordings have two player fatalities on the first pit.
the 319k made on Dec. 10 , the 326k on Oct 16.(right click on file ,to properties)
barthax showing up suddenly to confirm makes me think
a TWIN GALAXIES challange of some sort maybe.
Or not ?[/quote]
hard to say...I think the slightly higher score one showed just a minor degree of skill beyond the 2nd place.
maybe they know each other and have seen each other's play...where #2 is mostly copying #1...but doesn't have it quite as down. :P
The Pit....yes, death to all there.
ln2, one player copying the other's technique is quite possible.
and the date on the .inp is retained on playing over.
the initial day of play is kept.
sackville might have played around halloween and rewriting file since then.
sorry about yer luck
"Sackville" and "Jockel Gockel" are two different persons.
They are friends and have "developed pretty good tactics for the game as teamwork".
Barthax "showed up suddenly" :) because there's a thread on Ville's WOW record at TG forums, I'd imagine.
http://www.twingalaxies.com/forums/view ... highlight=
