Round 1 - Part 1 - Pang
Well, I'll put it on the leaderboard, and if Sawys or Marco doesn't want to allow it for some reason, they can back it out.
53 players on the leaderboard, which means all 1,460 points will be awarded in this part of the first round... 54th or worse gets 0 points if I remember correctly.
http://gameboy9.marpirc.net
No problem for me because we didn't precise it in the game rule.gameboy9 wrote:Well, I'll put it on the leaderboard, and if Sawys or Marco doesn't want to allow it for some reason, they can back it out.
- Marco Marocco
- MARPaltunnel Wrists
Mon Sep 24 13:40:34 2007 : LeClaqueurFou@jvrm.net (lcf) confirmed the pang score of 2938790 by BBH (bbh)
That one escaped to us until now because it was aready confirmed.
Alors le claqueur tu fais du zèle ... Tu ferais mieux de jouer plutôt que de mater les parties des autres
PROBLEMS...
i've some problems with login and password here... http://marp.retrogames.com/
please admin,verify my registration,
(activated 15th september),then PM my LOGIN
thanks in advance!
here's my INP...
- pang JOE.zip
- (55.33 KiB) Downloaded 313 times
Street Fighter2 H.F Master
Sergio...per sempre nel nostro cuore...
Re: PROBLEMS...
thanks in advance!
here's my INP...
- Zotmeister
- Button Slapper
Zotmeister's helpful hints: If you pick up a shield at the exact same time you take a hit... you're still screwed. You'll even hear the sound effect for collecting the shield as you die.
One guess how I learned about that one... - ZM
Darkness lessons learned/Avenging golden tresses/Yellow flower blooms
- "(dedicated to Millia Rage)", original haiku
same goes if you pick up a time stop clock at the same instant you get hit.Zotmeister wrote:Zotmeister's helpful hints: If you pick up a shield at the exact same time you take a hit... you're still screwed. You'll even hear the sound effect for collecting the shield as you die.
Stage 33 trick
Is the stage 33 trick allowed? (see GEMANT inp)
- Marco Marocco
