rongrong
rongrong
asn007
Post by asn007 »
I recorded it with standard settings plus joystick and mouse on. I don't have any idea why ithis recordings don't playback. ;( It's playback correctly on my PC.
You can try second rong rong recording http://marp.retrogames.com/inp/d/6/4/as ... olf117.zip
You believe but what you see
You receive but what you give
site admin @ http://www.nightwish.csk.pl
hmm, still can't play that one back either, same result. Using default nvram doesn't make a difference, unless you have a non default nvram/rongrong.nv file?
http://marp.retrogames.com/r/rongrong-rr
welby1
Post by welby1 »
I don't think RR uses nvram; at least it doesn't generate one for me.
youre right, just a guess. so does it playback for you welby?
Both playback perfectly for me, with no particular settings. Maybe something related to m63 bug ?
Chad, try to playback my own input to see if it playbacks or not
I CAN playback your (phil's) wolf 104 recording and germans wolf114 recording but i can NOT playback welby's 78 recording
http://marp.retrogames.com/inp/4/5/2/md ... wolf78.zip
but i CAN playback this welby recording
http://marp.retrogames.com/inp/9/5/e/md ... lf96u1.zip
strange. With full throttle phil's recording got me 30k but with no throttle it played back to 126200. But for the recordings i can't playback, even with no throttle they do not make one piece move...
Last changes :
0.114u1: Changed OKI6295 clock speed to 1022720 Hz.
0.106u6: Added pld ($0 - gal16v8b.1e).
0.96: Pierpaolo Prazzoli added Rong Rong (Europe). Renamed (rongrong) to (rongrngg).
Maybe some have effects ?
Blost
Post by Blost »
Chad wrote:can't playback either of phil's latest recordings, maybe mame63 bug.
http://marp.retrogames.com/inp/4/f/5/ph ... olf120.zip
http://marp.retrogames.com/inp/4/9/2/ph ... olf120.zip
both playback fine for me with sound and maximum FS.
Playback is fine for me too.
Chad, later I will send you some test inputs (-nosound -noafs etc), it could be 63 bug, but I'm not 100% sure of that.
Re: rongrong
giro-X
Re: rongrong
Post by giro-X »
Phil Lamat wrote: Sun Mar 15, 2020 7:33 am Could someone check one of these to see if playback is fixed on this game 13 years later :
http://replay.marpirc.net/inp/a/7/8/phl ... olf200.zip
http://replay.marpirc.net/inp/a/1/5/phl ... olf200.zip
http://replay.marpirc.net/inp/6/d/b/phl ... olf200.zip
Playbacked successfully (even alternatine turbo with normal speed) and confirmed them all
Re: rongrong
Thanks
