"loads" page anomaly
I don't know if it's related to recent script changes by Zwaxy, but when clicking on the "loads" page, several parts are strangely very long (see pic) ; anyone else has this problem ?
My loads looks exactly normal.
Maybe it has something to do with your browser or have you recently changed your monitor resolution?
Ok problem of width was due to java description of Alpha's extdwnhl input.
But I still can't get end of page (see below)
Phil Lamat wrote:Ok problem of width was due to java description of Alpha's extdwnhl input.
What do you have set as the maximum hits default in your "search" parameters?
I don't see why your "loads" page should be going back to November 2. Maybe the loading of the page is timing out or something because it is so long.
Set is to 200 hits, like always ;
that's the first time I got such an error, but you may be right
Phil Lamat wrote:Set is to 200 hits, like always ;
Try less (like 50) just to see what happens. 200 works fine for me, but that's an awfully long page if your connection isn't as fast as mine. (Goes back to October 27!)
