INPUT-VIEWER HELP
madmalk
INPUT-VIEWER HELP
Post by madmalk »
Hi all I'm new to wolfmame, MARP and anything to do with DOS but I have managed to play, record and playback an inp in wolfmame.
What I want to know is are there any good inpviewers out there so I can see what buttons/joystick are being pressed and if so where can I get them from.
I am using wolfmame 0.109
THANKS FOR YOUR HELP
i'm a newbie to using the inpviewer as well but wolfmame has one already built in. When you playback, you would use the options -inpview or -iv to turn on the display and -inplayout or -il to indicate what kind of keyboard layout you wish to view: -il standard (is regular joystick), -il mahjong (is with a keyboard like view for mahjong games), -il dualstick (for robotron like games), -il neogeo (for neogeos)
madmalk
Post by madmalk »
Thanks Chad since I posted I've figgered that wolfmame 0.109 has a inbuilt inpviewer in the configeration settings I've changed them to
# MISC OPTIONS
bios default
cheat 0
inpview 1
inplayout 6button
but it dosen't show the joystick motions and the buttons only flash up is there one that shows the order in which the buttons were pressed?
