wolf104 exception errors. :(
grazzy
Post by grazzy »
about 90% of the games Im trying to play/replay are causing exception errors. :(
my roms are ok, as normal mame 104 runs everything ok. I have tried many of the video settings (hwstretch, direct3d, etcetc), and none of them seem to make a difference.
Games that I know that work are total carnage (watched the replay), wboy, wbmlb.
Games that dont work: gauntlet series, pacman (lol), street fighter *, etcetc, tons of them.
What usually happens is the "OK" screen loads, I type OK, I get a black screen with a blue box in the top left corner, I hit enter, and bam, exception error.
heres an example:
C:\wolf>mameip104.exe tmnt
Exception at EIP=122B61E8: ACCESS VIOLATION
While attempting to write memory at 122B61E8
EAX=FFFFFE06 EBX=FFFFFF00 ECX=00000010 EDX=FFFFFF00
ESI=0092E908 EDI=FFFFFE06 EBP=00000000 ESP=0012FD9C
C:\wolf>mameip104.exe wboy
Average FPS: 59.999249 (245 frames)
as you can see, tmnt doesnt work, but wboy does.. :/
any ideas? its freaking me out.. I want to watch some of the recordings!. :-)
amd64 3200+ under winxp.
Thanks.
test any game/romset without recording or playback of an inp first....just to be 100% sure it's ok....not just a rom check.
Does this happen with other versions of MAME or MAME Plus? TMNT certainly works fine here.
Maybe your PC fan doesn't work properly.
Maybe your harddrive has problems, some of the roms located at bad sector. Try moving mame folder from c to d for example.
mahlemiut wrote:Does this happen with other versions of MAME or MAME Plus?
grazzy wrote:...normal mame 104 runs everything ok.
I started getting the black screen with the little blue box in the upper left corner in WolfMAME .103. Stays like that until I press "Esc" or "Enter", then proceeds normally.
Haven't tried .104 or other MAME versions.
Very rare, but I sometimes get this "access violation" message ;
last example :
http://marp.retrogames.com/inp/0/a/3/kb ... wolf92.zip
Note : I also have an Athlon
Weehawk wrote:I started getting the black screen with the little blue box in the upper left corner in WolfMAME .103. Stays like that until I press "Esc" or "Enter", then proceeds normally.
That'll happen for anyone. As far as I know, it's a bug with Visual C++ 2005.
Caseh
Post by Caseh »
Hi Grazzy,
Sadly I had the exact same problem and odly enough we both have the exact same processor. I started a thread here viewtopic.php?t=12394&start=0&postdays= ... highlight= to try and resolve it but never did. Some older versions of mame worked fine and others didn't.
In the end I formatted and went back to win2k instead of XP, solved all my problems and XP is crap anyway. :wink:
DRN
Post by DRN »
I had this problem almost a year ago and still have it today, mostly with Toobin but it affects other games as well. Haze came up with the solution that it's a bug in MAME.
The original thread can be found here
viewtopic.php?t=12143&highlight=
Darren
grazzy
Post by grazzy »
Ok, so I guess the conclusion its a mame bug.. but only a wolfmame bug? Like I said, normal mame runs everything fine.
Maybe is there some way the person who compiles wolfmame can try it with less optimizations.. maybe thats the culprit? Or maybe theres a non VC++ wolfmame? I dunno, just throwing out questions here. :)
Just sort of sucks cant watch a lot of the inputs. :(
Oh well. Maybe next version will work better. :-)
Thanks for all the help.
I use VC++ 2005 Express Edition to compile, mostly because it fails to compile in GCC 3.4.2. Actually, it causes GCC to completely fall over. There is something similar under VC++ as well, but that was fixed by using a compiler directive to disable optimisations at that particular statement.
Not sure about completely disabling optimisations, as I'm sure people will want as much speed as possible. Finding the particular problem won't be easy either, as I can't reproduce the crash at all. I'll have a look at disabling general optimisations (there are no CPU specific optimisations in VC2005) and see if it makes a major difference in speed or not.
zlk
Post by zlk »
I just bought a computer with an AMD processor and was having the same problems. Make sure that DEP is only running on essential windows processes and I think it will cure the problem.
Right click on "my computer"
Go to properties
Go to advanced
Go to performance and click settings
Go to Data Execution Prevention
Click the top option so it is only running on essential Windows programs and services only.
I hope that works for you. 8)
grazzy
Post by grazzy »
This worked for me. This was a clean install of XP and I forgot to turn that shitty DEP off.
Stupid Microsoft, stupid AMD. :)
Thanks, hope it works for others as well.. (so its not a mame problem...)
Still "access violation" crash trying for example to playback :
grazzy
Post by grazzy »
Phil Lamat wrote:Still "access violation" crash trying for example to playback :
where exactly is it supposed to crash? I just d/led it and ran it for about 10 seconds, and the playback was going fine.. Should I wait longer to test?
that dep did see to fix all my problems though..
