I've discovered that the game doesn't playback if you record without Frameskip 0.
But with -noafs used, the game only playbacks when you press F10 at the beginning, it desyncs if you playback it at normal speed :
try this one
http://marp.retrogames.com/inp/b/4/3/ph ... olf104.zip
After I've recorded with -nosound -noafs :
http://marp.retrogames.com/inp/9/e/9/ph ... olf104.zip
Then it playbacks ok for me with or without pressing F10.
But Notman only got it to playback when pressing F10 ;
maybe he's not in the same set of PC than me ? 63bug?
Don't really know ...
does anybody else get mine to playback at normal speed ?
And last question :
can anyone playback one of the top three scores ?
maybe as they weren't aware to use -noafs, these inputs are unplaybackable and should be disqualified ; need 3 testers, please
Madball playback : strange thing
I was able to play http://marp.retrogames.com/inp/b/4/3/ph ... olf104.zip back with out using F10, i used -window nd playedback throttled.
MAMETesters
Has anyone brought this up yet on the MAMETesters forum?
Kranser.
Kranser.
