PuzzledBrain_ BRs recording only plays back to 2nd event at which point it misses the qualifying score and the games ends: 6pts. < I'm guessing its desynced as advertised score = 42 pts
http://marp.retrogames.com/inp/b/a/9/pb ... olf103.zip
On another note, could someone check my recording for this game. I remember I had to record it like 6-7 times before I got a recording that played back OK for myself but it hasn't been confirmed yet.
http://marp.retrogames.com/inp/b/f/3/gt ... wolf98.zip
machbrkr
Same for me :
PuzzleBrain won 100m with time=9"55, then failed twice when dragging the monster ...
I'm afraid it's the same problem than with numanath (an old war between me and TJT) : -fs 0 sometimes works, but not often.
Machbrkr is also known as Numan Athletics II
I will check your's tomorrow, Caseh
- Button Slapper
INP error...
Ops, so it didn't work...
I played until Day 3, losing only in Monster Hole...
But the INP Record is strange, sometimes works, sometimes I lose in diferent events...
The question is: what I have to do to fix this ???
Re: INP error...
If you are using mameip103.exe(commandline) try -noafs(no autoframeskip) option.PuzzledBrain_BR wrote: The question is: what I have to do to fix this ???
At mame32ip103(frontend): options-default game options-display-uncheck frameskip "automatic" and leave it at "draw every frame"
(if the game plays too slow then, change it to "5 out of 12" -anything but not auto)
-This changes default settings for all games. If you want to change properties for only one game, click the gamename with right mouse button and select properties etc...
Some games are very hard to get playbacking properly, luckily only few. Fixed frameskip often helps. Sometimes disabling sound. You should allways try to playback recordings yourself to see if they work.
Remember that autofire or RLH-cheat is not allowed.
Okay! I recheck PB's machbrkr replay on W98. It does works on W99 cmd line and I'm not quite sure what wrong with W98 GUI! Probably is M.63 bug somewhere.
Sorry PB! I thought it wasn't working correctly after few tries while talking to Phil. So go ahead beat your record, again!
Phil's machbrkr replay works on W103.
Later,
NotMan
Later,
NotMan
