f1gpstr2
f1gpstr2
http://marp.retrogames.com/inp/6/6/5/tj ... olf100.zip
Desync on 3rd lap for me, and also for Notman (we talked about that on the chat)
Anybody else ?
3rd :wink:
I thought this did playback for me, but now it doesn't.
I'm definite that I passed the car that caused the playback problem. I recall thinking though that it was unnecessarily close one.
...submitted new one. This game seems to have some playback problems similar to Stun Runner...Where you can playback your own recordings only for few levels untill playback desyncs.
Often desync starts from a collision to an opponent(car)that you did not collide into when recording.
Both are analog games, f1gpstr2 I play with mouse, stunrun with great joy.
It would be so nice to have those 9 or so firsts from Stunrunner... :(
http://marp.retrogames.com/inp/d/1/3/sc ... olf102.zip
(+other inp included in zip)
Doesn't playback correctly. Playbacks to 2,5 full rounds=5M points
This game has serious playback problems, you (and I) should allways check your recording before submitting. My current submission should playback.
It doesn't for me, neither for Notman, but Barry managed to get your time.
It's an other problem than for f1gp, it's linked to analog stuff
3rd on schindler, goes into grass and stays there on third lap of first race just after boost is hit.
Gerhard S
Post by Gerhard S »
Gerhard & Crew Pinballs
http://schindler-gerhard.de/
Try f10 for playback. It does playback for me, so it is supposed to work for someone else too.
I suspect if you want playback to work at this game, you might want to try -frameskip 0 (/draw every frame) when recording.
And for heaven's sake, check before submitting if recording playbacks for you. Pardon me if you did do that. :)
Gerhard S wrote:no playback with wolfmame100
http://marp.retrogames.com/inp/c/8/a/tj ... olf100.zip
hmm i can't play back this one either, dies at third lap again, very similar place to where gerhard dies. Same thing happens with fs0 or fs11 nothrottle. 3rd? :)
I believe Phil said that Barry was able to playback that one.
This is one of the games which is never going to playback for all. IMO one that is able to playback it should be sufficient, after all you need only one person to confirm a score.
If you can see couple rounds, then you've actually seen all the tactics already, rest ain't gonna be different.
ahh, no. If one person can play it back it could mean that was the time it was only able to playedback once and never again, at least with two people outside the recorder's frame of mind that chance is nullified.
I disagree :)
cool enough, :) I also would like to commend you for a very good year of managing marp's regulation. you'll be hard to beat this year if you still want the job.
Thank You very much Chad! :oops: :D
Your work and expertise is highly appreciated here too!
The TJT wrote:I believe Phil said that Barry was able to playback that one.
Right, he managed to play it back ; I don't remember exactly what he said, he talked about an -override, but went to sleep just after that, leaving both Notman and me unable to play it back
(you also die on 3rd lap for both of us, Tommi)
Barry ?
It played back only without -override, but was fine otherwise.
